as title says toasted tranny, so i'm going to rebuild motor too. its completly stock w/te44, 3" dp, 42's, adj fuel reg, walbro 340 hot wired, & scanmaster 2.1. it's a 87 and i've only owned the car for about 8 months. rebuild will include putting billet caps on bottom end, i've accuired a set of stock irons cnc ported w/ big valve, going to port intake & throttle body , 212 roller, going to around 80lb inj, keeping stock crank w/ scat rods & a good set of forged pistons. going to run te44 for now. converter will be picked according to my final turbo size. car is a daily driver/weekend warrior. mostly 8th mile tracks around here with beech bend being closest 1/4 mile. would like solid 6.50 car in 8th which would be mid 1o's in 1/4. i guess big question is what is the best turbo. been looking at 6265 but i have master power 70 w/96 exhaust housing laying in shop that i was going to use on a ls motor. can i use the 70 and change exhaust housing to an 81 with about a 3600 stall. what do you guys think and i know i'll have to do a litte fab work with mp70, that's not a problem. thanks Ben
