Your blowing through that converter, it was a common complaint of that vintage multidisc lock ups. The transmission governor is driven by the output shaft, which means the WOT shift points are based on the governor and the output shaft speed. More converter slip will raise the RPM of the shift points. If your TV cable is tight when the throttle is open all the way that's not a contributor. Also, using converter stall speed numbers is not going to get you anywhere. The turbo6 power characteristics requires specific converter characteristics which will be WOT coupling RPM, max boost brake stall rpm, and converter flash rpm. If you are on a budget then you will have to trade off something. I personally would prefer a tighter converter, if I had to compromise, to keep the rpms in check and in the meat of the power and sacrifice spool up, unless you are planning to drag race a lot then you have think about 60ft which means you will likely have a fair amount of slip unless you want to spend to get it all. Some numbers for the PTC below and it drives great for cruising. That combined with the Husek transmission is an awesome street/strip combo. Additionally, I can get 4400 rpm on the foot brake and over 20 lbs boost really quick, flashes to 4700 rpm when I let off the brake, and drops 2 to 300 rpm on the shifts. Shift rpms in table below.
tire dia | 27.3 | 27.3 | 27.3 |
shift/trap mph | 30 | 64 | 119.75 |
Rear ratio | 3.42 | 3.42 | 3.42 |
Gear Ratio | 2.74 | 1.57 | 1 |
Shift/trap Rpm | 5120 | 5040 | 5400 |
DS RPM | 1263 | 2695 | 5043 |
Input RPM | 1869 | 3210 | 5400 |
Slip % | 32.4% | 16.0% | 6.6% |
