torque specs?
MY T FAST
i realize this should be in the trans section, but i figured i'd get a quicker response here.
does anyone know the torque specs on the valve body bolts? and the tranny pan bolts?
also one other question, can i use a tranny filter from autozone, or did you guys get a genuine ac replacement. just wondering. thanks a bunch!
Talon
Check Gnttype.org I would say about 15lbs for valve body and 20 for pan. Im sure you can use the filter from autozone, just make sure it fits good after you intall it and put some lube on the oring before you install it.
