rodman99999
- Mar 25, 2004
Has anyone ever done a torque reading on what it takes to turn a 3.8 short block? I just assembled mine/installed cam, and it seems kinda tight. Clearances: mains- .0016(torqued to 90lbs, ARP studs), rods- .0018(torqued to 50lbs(ARP bolts), piston skirt/wall- .0045, rings gapped to .0022(plasma moly), crank endplay- .006. I used the red assembly lube on the bearings and soaked the pistons in 5W-20 oil. I've only been turning it with a 10" adjustable. Gotta get my big 1/2" socket set from where my car's parked(building the engine in my dining room), so I can find out how many ft/lbs it's taking. Should I worry?
