TPB 2022
t racer
New engine installed after 10 years. Feels like light miss at idle maybe all the time. Compression 150 psi. NGK UR 5 GAP .032. Has updated ign module new wires. new fuel pump 30 psi at idle snap the throttle up to 40 psi. Disconnected vacuum from EGR. Vacuum 15 inch steady running.Scanner check sensors seem to be reading correctly. Set cam sensor per manual. Any thing to check next? Thanks
