I finally got a scanmaster. And I am trying to get everything set. I cannot get TPS settings right I tried filing out (2) mounting holes to elongate the holes a little. But to get W.O.T. to read 4.6 volts my idle volts is at .50 I tried to back down the idle to read .42 but car keeps dying at around 600 rpm. If I get car to idle good and set TPS to .42 W.O.T. is only 4.38-4.44 I have a TPS-Tec that gets W.O.T. to go to 4.75 volts, but from what I have been reading on here these are not good to run. I bought only about 10 years ago to fix this should I remove this. Any ideas.
