deezdad
- Mar 25, 2005
Which would you run for a 11.5ish street car, te44/alky? Why?
SignUp Now!I run alky/93 no issue with all stock stuff. Good wires and good grounds!
stock stuff works great.i have seen stock down to 11,10,9,8 sec buicks on the stock ignition setup and on a lot of different fuels.Which would you run for a 11.5ish street car, te44/alky? Why?
Coils are readily available but the nos modules are rare and nearly cost the same as the TR6. The new modules out there are not built to the original specs. Can't run an aftermarket rpm gauge with them either. Run it till it fails then go TR6. You can then leave that worry off the list.
