- Nov 30, 2009
Who else makes plug wires for the TR6 ignition besides Kirban & Fullthrottle ?? I wanted a different color choice than red or grey . Thanks , Sam
SignUp Now!I bought the ls terminals from taylor I forget what number has the 90* boot at the coil...this was important to me to not have the wires coming off the coil weird. Then I had a spool of wire and bought the tool from summit. Now I can replace wires at will just because they have the writing worn from themTo make your own , do you just buy the universal kit ? Does it have the proper end for the coil pack ?
Also, don't forget. If you are mounting your coils on or near your valve covers, all you need is the boots for your coils. Because you can use your existing wires and just cut them down to the proper length. You should also have enough left over for another spare set as well.Thanks Toby , I went to the Taylor website and found everything I needed . Can't wait to put my new TR6 ignition in .
I'm mounting the coils in the stock location , but thanks for the idea .Also, don't forget. If you are mounting your coils on or near your valve covers, all you need is the boots for your coils. Because you can use your existing wires and just cut them down to the proper length. You should also have enough left over for another spare set as well.
