See the thing is if you fix the header you will get better 60' times even if you launch at the same boost cuz it will spool MUCH faster...Also it'll be more fun on the street.
You should always fix what you have wrong before you upgrade other parts...A 49 should spool fine with a stock converter, if you upgrade turbos later then it'll be necessary to get a converter.
