JDSfastGN
- Jun 16, 2001
I went to the track for the first time in about 5 years this past Saturday. Weather was good for this time of year at about 900-1000 ft DA.
My previous best had been an 10.70@127.8 on a basic combo.
Girdled 8.8:1 234 ci,
ported stock heads with bigger valves,
210/215 FT roller, PTC 17 blade,
6776 23/21 timing and 25 psi.
Home-made FMIC (ebay core w/no leaks)
Alky/93.
28x9 Hoosier bias ply slicks
3.23 gears
After hurting my old setup I came across a fresh 249 setup I couldn’t pass up. My new goals were a 10.20@132
My new combo is a 9.0:1 249 stroker
“THS special 6768 dbb with a 3”x2” cover
21/18.7 timing with 28-29psi
1.65 roller rockers
Same iron heads freshened
218/212 roller
Full -8 feed, -6 return dual fed fuel system
PTC was tightened to a 16 blade with a sprag added to try and help it to couple efficiently.
28x9 MT ET Pro Bracket radials
Dual nozzles added to alky
3.23 gears
All runs were off the Tbrake
Saturday I started off poorly with the car surging through every gear and ran an 11.3@114 with a 1.58 60 on 23-25 psi
I turned the alky down from 6.5 to 6 and took some fuel out of the base fuel setting on my TT 6.1 chip. (My powerlogger didn’t record so I couldn’t see what was happening BLM wise at WOT so I took a chance. Scan master showed 10.5 a/f as the leanest with 1* knock
Next pass I cut a 1.52 and it went 11.00@122.5 and boost was 24-25 down low and 26-27 in 3rd . The mph seemed really low for the boost and combo so I went and tweaked the fueling again
I pulled alky back to 5.5 and made a pretty clean pass and a new best by a hair. 10.61@127.43 with a 1.49 60 ft launching at 13-14 psi. This time I actually got my powerlogger to record and I saw it was actually trying to add roughly 10% fuel throughout the run.
I added base fueling back into the chip and added a 1* of timing overall. I ended up getting on the brake but had to back off when the other driver had issues with the tree and pushed through so the trans probably got warm. This run felt weird and fell off significantly to a 10.955@122.9 despite 28-29 psi and a consistent 10.5+/- a/f. The BLMs this time were starting to peg out at 170 to try and keep in line with my target a/f ratio. I knew something wasn’t quite right but really wanted to compete in class racing that was about to start so I went to make one more pass to see if I was gonna stay and compete.
I added base fuel up to 22% and left it all alone. I let it cool off for about 30 minutes or so and put my fuel pressure gauge in the windshield. The car left hard and pulled another 1.49 60 ft with about 15 psi off the trans brake. The car was pulling smooth and strong but what I assume was around the 1000 ft mark I saw my a/f ratio take a dramatic turn upwards to 14.1:1. I reacted slowly and kept in it through the run I’m pretty sure looking at the logs. Car seemed fine and registered 0 knock during the incident. The BLMs were pretty solid at 124 until it went lean and it tried to react. I tried to read the fuel pressure gauge but it had slid down a bit and the lighting was so poor I couldn’t see if it had dropped or not.
The bottle necks I can think of
Ported 62mm stock TB and matched plenum- not sold on this being an issue as many have gone much faster
Ebay intercooler (slightly bigger than an RJC) IATs are kept in check and generally drop from a bit over ambient to below ambient mostly due to Alky. I don’t know if the turbo is pushing 40 psi to get to 29-30 in the plenum
Big Valve Ported Irons, I really thought 28-29 psi would put me in the 6768s sweet spot but would I need 31+ to reach my goal on Irons?
Converter- Despite being a tight 16 blade with a sprag added 9.5” PTC I am seeing slippage up near 14-16% using the TCI calculator and my trap speed (Ignore any power logger mph since it’s based on my 25.7” tall street setup) On the higher boost settings im seeing about 500-650 rpm drop down to 4950-5000 rising to 5700 or so through the traps.
Shift points- I could probably benefit from taking some weight off the governor and getting shift points up near 5900-6000 but I’ve never had it on a dyno to see where it peaks and starts to really fall. I’d imagine peaking at 52-5300 or so. I can feel the 1-2 shift during the runs but it’s not very obvious on the logs as it shifts a bit earlier around 5200-5300. The 2-3 was between 5500 and 5700. The trans felt solid throughout the evening.
*All passes have been done on a 3” MAF pipe and 3.5” LS1 sensor and translator and TT 6.1 chip.
Alky/93.
3.23 gears
1.65 roller rockers
218/212 roller
3.23 gears
