i think you did ok but
what were you running for fuel ,
what were your O2s
what are you running for tires
whose chip and specs ,
what boost were you leaving at
might want to up the fuel
it was cold last night at the track , like 49* when you made that run ,you have to watch because youll find youll need more fuel when the temp drops
i had poor traction all night and others had good luck , lots of junk on the track
also when you pull up to burn out move up a little more , try to get your tires out of the water and off the concrete , try to get into the rubber and resin pit
