If I crank up the boost or timing, I always use C16, why not? Good insurance to keep motor together. I even add methanol to further raise octane, and lower intake temps. Always start off rich, and with plenty of octane. If you are seeing no knock, and a rich condition, just crank up the boost, or cut back on fuel, but not both! I run 30psi on a stock motor. It will last a long time the way I tune it. A little rich, not to aggressive timing, and plenty of octane! Tire pressure is important to get rid of wheel hop. Listen to the pros! Too much/too little is going to make for bad results. What knock guage are you using? Have a friend tap on block lightly while motor is running (with a small hammer or tool) and look for knock. See anything? Further tuning will most likely get you deep into the 12s. Make notes of all changes and results! Gas, boost, chip, timing, weather, tire pressure, launch method (#s of boost),etc.
