TurboV6Olds
- Jan 24, 2010
I currently have a stock G80 rearend with Bilstein shocks, Metco lower and adj. upper control arms, and Eibach 1" lowering springs, All the bushings on the stock control arms were replaced with poly bushings which was supplied with the control arms. Does anyone know what pinion angle the rearend should be set at or is this something that has to be played with at the track? Any info would be greatly appreciated.
Thanks in advance for the help!
