- May 28, 2001
Attn Florida Turbo Buick owners.
I will again be doing transmission fluid changes, i was able to get a machine again til i acquire my own.
What it does is connect to your cooler lines and runs in circuit with your transmission cooler. It efficiently changes 99 % of your fluid without dropping the pan or spilling a drop of fluid on your arm. The machine is run by YOUR tranny pump so no extra pressure on the seals and NO oil starvation because it supplies new fluid as the old is pumped out. The whole process takes 15 minutes tops.
The basic charge is $50, i will provide Dex 3 and dispose of the old.
The premium service is $70, it is the same as above but uses a 50/50 mix of Dex 3 and Chevron Torque fluid.
You can email me at IrvJr@earthlink.net
Thank You
Scott Irvin
IrvJr@earthlink.net
Thank You
Scott Irvin
IrvJr@earthlink.net
