tranny lines
If you do go back to stock, steel lines be aware that you have to take the engine out in order to install them. I learned that the hard way. One of the few bright spots in my blown-engine saga is that I can now install the transmission lines I bought from Classic Tube.
Jim
Ok so now you guys got me thinking twice about my rubber lines. What do you do if you have an after market cooler? Im assuming these lines are for the stock cooler in the radiator.
Yes, typically the hoses to aftermarket coolers are rubber. The factory lines for the stock, internal cooler are steel.
Jim
