Tranny pressure guages?
NCTURBOS
Gettin' back in action!!
Staff member
Just wondering what everyone is using for their pressure test guage? Especially for ease of installing, checking pressures, and removing for multiple vehicles...
K.
nothing is EASY
I put a 45 degree (1/8 in. NPT X 4 AN ) fitting in the port--pointing down and toward the front --about a 45 degree. I have found this is easiest access when putting nut on the adapter fitting. A 6 ft. 4 AN line with a min. of a 300 psi gage on the other end. This gives you enough length to tape the gage to windshield. Running the line down and then up AWAY from exhaust. I once had some extra lines with gages on them but have given them away to friends. You could make your own if you can come up with the necessary fittings. I once though about making them and selling but figured the market wouls be small and have to eat half of them. I leave the fitting in the side. Keep in mind when sizing a gage --it needs to be able to read twice what it will see @ max. A rule of thumb, I suppose to protect gage. I have use a 300 lbs. gage with it reading 250-275 and it appears to still be accurate. Best of luck.--Lee
The Snap-On kit retails for $399, but can be found cheaper. The Matco kit sells for $130, which isn't too bad. This is my fourth or fifth time borrowing one so I figure it's time to invest...
Lee, You're saying you leave the 45* fitting in the case, so it's an easy hook-up for each time you want to check the pressure. What are you using to cap the 45* fitting when there's no guage installed?
K.
