sounds like the spring has sprung on the shift ...at the bottom of the shifter handle there is a spring the holds up the piece that makes the gate work it is the spring you feel when pushing the button...pop out the ashtray and take out the two screws under it and you can remove the plate around the shifter then look at the base of the shifter and see if there is a spring wrapped around the bottom holding the rod up..
