- May 26, 2001
Welp, Tracey and I took Sarah to the track tonight.
Absolutely perfect weather, overcast skies with temps in the 60-58* range. Track was hooking very good as well. Lot's of wheels up launches from other cars. Since my last track visits I've changed three things.
PT6776RHP turbo with HD actuator and .63 A/R housing
RJC 375 FM Intercooler
BuickGN Big Mouth cold air kit and 4" MAF pipe
I took the car out for a spin back in August and could feel the tranny slipping between shifts. I knew that the trans only had about 2-3 more passes left before it was all she wrote. I also could feel the car falling on it's face at RPMs above 4500. On a hunch this past Thursday, I put my Caspers coil pack tester on my coil pack ignition module and thought I see if maybe my hunch was correct. Twisted the knob and yep, the spark completely went out before I had the knob turned half way up. I ordered both parts from Gyrhead & Sons. Got the coil on Friday, but UPS screwed up and didn't deliver the Ign Module on Friday. So, I took my original 20 year old ignition module and installed my new coil and retested. All was good, strong spark all the way to max. Put it back together, rolled the wheel well trim with an 8# mini sledge hammer and took off the cat con.
Made it to the track, drained 1/2 gallon of 93 pump gas out and poured in 10 gallons of C16. First pass went like this.
E-braked at 12psi. Boost went to 23psi and the car felt strong until the 1-2 shift. The trans slipped and slid on the 1-2 shift for about 1 second. Figures. I told myself, welp, here comes a 12 second pass. I lock the converter after the shift to 3rd and breeze through the traps. I hit recall on the return road and see .761 O2 and Zero KR. Not too bad, but how badly did that 1-2 slipping hurt me?
Time slip read 12.48 @ 107 with a 1.66 short time. Sigh... The trans is done. I decided to let her cool for one hour and if she slipped again, or worse, I was done and it's time for a trans.
2nd pass, I turned up the boost to what I figured would be 25-26psi, added just a little bit of fuel under WOT, took some fuel out of 1st and changed the timing to have 27.1* timing in all gears. Gotta love C16.
2nd pass, did a good smoky burn out, second one ever on these new ET Streets. As I was spooling up on the E-brake, the car was bogging down like PE was trying to kick in and flooding the car. Boost was slowly building up. When I saw 17psi on the gauge I let her go. She literally jumped sideways hooked, spun and hooked back up in the first 10 feet. DAMN! She's making some power now I thought. Time for the 1-2 shift and I will try to describe the action with words.
AhhhhhhhAAAHHHHHHHHHHHHHHHHHaaaaahhhhhhhAHHHHHHHHHHHHHahhhhhhhhhhh!
Like it didn't want to shift and was slipping very badly at the same time for over a second. 2-3 was fine and I locked up the converter and felt a nice thunk when I hit the switch. Boost was at a rock steady 26psi and she was honking. O2s were headed south, but I didn't see any KR on the big end, so I stayed in it. Crossed the traps and thought, ehh, she's definitely making more power, but the trans is really gonna kill the ET. I bet it's only a low 12. That slip was horrible.
I hit the recall on the return road and my heart jumps up in my throat.
.695 O2 and 9.1 KR. YIKES!!! I hit both buttons at the same time on the Scanmaster and see that the .695 was at 84mph and the 9.1 KR was at 40 mph. Ok, whew. The KR was while the tranny was getting stupid and not on the big end. So, she wasn't running 27* timing with O2s that low through the traps.
I get my slip and it reads,
1.66 60ft, 12.38 @ 108 mph. Yep, I'm done, trans is toast. She is definitely making power and I know for sure, she'll run easy 11.30s with a fresh trans and my 9" Art Carr converter. I gave her the once over back in the pits and all was well, coolant smelled and looked good, oil looked and smelled good, she was purring like a kitten during her cool down and temps we very stable in the 165-168 range.
I packed her up and Tracey and I made the 60 mile trip back home without any problems. Tranny is definitely toast tho. But I know she's gonna fly with a fresh trans and the 9" Art Carr converter I have here waiting to go in.
Here are a few pics of my current setup.
Can't wait to get a new tranny and install this converter. Looks like it's time to give Brian a call once I get some scratch together.
Thanks for reading everyone. 11.30s are in the cards for next year.
Patrick
Patrick
