Power to terminal A is routed through your brake pedal switch. You should have a constant 12V as long as the key is on. Power to terminal A is cut when the brakes are applied.
The TCC circuit, when active, uses less than 1 amp.
I'm not trying to insult you but I need to ask this. You are probing the vehicle wiring harness and not the transmission case connector, correct?
