The Darkside
Heavy Metal Thunder
- May 25, 2001
I know that it's suggested that you set your fuel pressure for 45 line off w/ this chip....but how many of you are actually able to set it at 45 line off & keep your blm's @ 128 & have the car great at WOT?
I'm asking because at this time athough my car seems to be running pretty good, I was told that since my fuel pressure is set at around 41lbs line off that I'm losing out on alot of horse power.
My blm's are showing 128 at idle...
02's are approx 750 top of 3rd gear....0 knock
Boost set at 22-23 lbs
Razors single nozzle alky kit...knob turned approx 90% all the way on
And of course my fuel pressure is set at 41 line off...
The car does run rich at launch....o2's in the 820-840 range...
Would it improve my power/performance to...
1)raise fuel pressure to the chip makers recommended 45 line off...
2)reset my ecm & drive around for 10-15 minutes & see where my blm's are at
3)adjust the trans+ to run richer or leaner at idle..
4)subtract fuel from the trans+ wot setting to get my 02's in order..
5) adjust alky??? hopefully down as it's about maxed out & I'm only running 22-23 lbs of boost & I know this 70gtq has alot higher sweet spot...
Let me know your initial thoughts & tomorrow I'll test again & post what the egt's are at wot..
