Jul 13, 2002 #1 D Dalt10 Guest Can i take out the trans-go shift kit and put a PTS shift kit? does the trans-go modify anything that can't be reversed?
Jul 13, 2002 #2 H HOTTOGO Never Enough!!! Joined Apr 6, 2002 Messages 964 If you have the instructions and know what went in and the VB "WAS NOT DRILLED" it can be removed and replaced.
Jul 13, 2002 #3 M MeanBuicks Scaring the neighbors! Joined May 24, 2001 Messages 3,658 Most Trans-Go kits have you change virtually every VB spring so you'll need to return many of the stock springs back into the valve body.
Jul 13, 2002 #4 C Chris Taylor Guest Trans Go shift kits are a POS!!! I have a junk valve body due to the Trans Go kit. Trans Go tried to reinvent the wheel with their shift kit. Get the PTS kit and you will never need another shift kit. It is awesome.
