83hurstguy
- Sep 18, 2005
was home for the weekend, took some press. readings on my trans. Has Chris' shift kit in an otherwise stock OZ 200-4R. Trans shifts a bit hard at light throttle, gets mushy as you get on it more...
here's the readings I got:
min TV max TV
P 85 220
R 135 180
N 85 220
4 85 210
3 85 190
2 190 190
1 180 175
On the road... at 1/4 throttle, the trans was moving about 120 psi, at 1/2 throttle the press was about 150 psi and dropped 5 psi on the shifts, at 3/4 throttle pressure was about 160 psi and dropped 10-15 psi on shifts, at full throttle, the pressure was 150 psi through 1st gear (went down? we triple checked that) and pressure dropped about 15 psi on the shift... the 2-3 shift at full throttle was at about 130 psi.
so... let me know what you guys think of these readings... the trans also bangs like a mofo at random times when getting shifted from P to D or from Rev to D. Rear end and u-joints are in great shape, as well as the trans mount. I didn't see any crazy pressure spikes when shifting between those gears. any ideas? I am
Thanks!
min TV max TV
P 85 220
R 135 180
N 85 220
4 85 210
3 85 190
2 190 190
1 180 175
Thanks!
