Trans problem found....anyone have this happen??
87BLACKBEAUTY
hi guys had trans tore down yesterday....pan was clean no frags..converter is fine...clutches fine....but the pump gears were broken in half..anyone every had this to happen before?...my brother said he has had them to break on toyotas,,etc..other makes but not on a GM before..he said thepump housing it self is fine just the rotator(pump gears) busted now i know what that cliccccckkkkiiinnnng noise was when it stopped pulling...he said trans seems to have been rebuilt before but no clue on when it was done just that every thing looked great inside...he said he would leave it up to me to do a total build or just replace the pump parts...so i told him just do pump parts...also he has replaced the ROPE SEAL with the FEL-PRO NEOPRENE #BS 40613...I suggested not using the side pieces but the black sealant instead...but he said he has used the sides and nails before on many of these type rears with no problem...so i left it up to him...he also said the bearings are in great shape for the mileage thats on the car..hes going to replace the engine mounts on the car before he replaces the trans..one on drivers side broke....i need to know the best oil and additive for this time of year...would a 10W40 be to brawny for the winter..if so what do you guys suggest..and how many quarts...i seen somewhere VR1...thanks..:cool:
Broken Rotor isn't a common problem but, it does happen, more so with the 13-Vane Rotors. Make sure you use the proper thickness Pump parts and the clearance is correct. Billet Steel Rotors & Slides are also available.
Good Pump Info about 3/4 way down Pg. here >> Answer Question
As for Oil, use oil with the correct amount of ZDDP additive for Flat Tappet Cam. There are a few Threads on here with Info on several brands.
trans has been out... When replacing it, converter wasn't seated, cracked the pump...Finally gave up.
cool...thanks...sounds complecated but great info
When I ran a 200-4r, I cracked a pump slide. On that pass the car was pulling hard.......then nothing but neutral. It was a 7 vane pump. Didn't hurt anything. Put new slide and rotor in the trans and it was fine.
