SignUp Now!Just got the Estimate for my Engine...hope you are all sitting down How about $5000 plus sales tax which is around 7% in NJ... That was for forged pistons, roller cam, turning the crank down a little, exhaust valves and machining the heads and assembly...Too Rich for my blood...:frown: Going to go pick up my parts and punt.
Charlie, I was checking out the Series engine here put in that GN...Man that looks like one rock solid engine.. I have seen these engines in the regular cheap section of the Local junk yard too...What is the best one to get?? and what cars did they come in ?? I will do more checking about this on line too...That block setup and heads look a ton more solid than the 3.8 do you have any idea if the computer is linked to the Speed o meter ?? I guess I would have to take the dash out of that car too.?? I guess you would need the computer to regulate the injectors right..>>? What I like is it looks a lot like the 3.8 and I might be able to pull it off as a opitional engine or something...almost...I guess with a little imagation.:wink:
I don't understand why some members think they need high end parts to build a fast car? Forged pistons are a waste of money. Just get a engine kit for a 83 turbo engine and use your standard crank. Then spend all the money you saved on getting the heads redone and cleaned up. My car doesn't have forged pistons. Seems to run fine to me. No one makes fun of me for having an 82 shortblock in my 87 we4 either. Put your money in the heads and get a 204-214 cam. With a draw thru, the more power you make n/a, the better. Get a d5 stall to go with the OD trans
I agree that forged aren't required, but with the tendancy of the draw through system to detonate it's cheap insurance. Remember that we don't have the same options as an SFI car to be able to adjust timing and fuel curve so we have to be extra vigilent on the parts and equipment we put on. We shoot blind compaired to the other guys.![]()
Charlie, your starting to sound like Jack Merkel now..You gave me a lot of food for thought..I guess I have some digging to do...expecting snow tomorrow.Will let you know what Jack thinks about the 3800 engine..
I will agree with you on this one. Draw thru setups weren't given the best tunes even right out of the box. But why not just get a knock detector and a wideband that way there IS no guessing?
Well I've done the research on what I intend to do and I don't want to spend 5K and watch it blow up first time on the track.:frown: I think I'd sell the car at that point.
There is always guessing with a draw through Jesse. The only thing I'm missing at the moment is a wide band and a timing controler for the MSD unit. So far I've got a 6A, BTM, ported headers and parts to build a second set of KB style. I really believe in being prepaired so I don't have any issues with it.:biggrin:
id love to see some more progress there charlie, if you need a hand, im not doing chit anyways:frown: till school restarts again that is.
