TurboWh1
- Aug 12, 2002
I've been thinking about having my tranny rebuilt again. I'm not sure what is causing the problem or if a rebuild is necessary. It slips from 1st to 2nd only when the boost is above 20psi on the drag strip. Can a converter cause this issue? The other problem is it periodically hold the shifts and slams the gears at part throttle on the street. Usually after sitting for several days and always cold. The strange thing is while normal driving on the street it works as it should. I've attached a video so you guys can see how its slipping. My video is kinda shacky but if you listen you can hear it slip 1st to 2nd. Just copy and paste the link below.
MOV00951.flv video by TurboWh1 - Photobucket
