jpwalt1987
- Nov 9, 2003
Hey guys I am still working (20 hours of upgrades and unf#%*ing hack job installs) on a local guys GN and the final issue the car seems to have is a funky 1-2 shift. I talked to the previous owner and he told me a trans go shift kit was installed by the owner before him. (This car has changed hands alot) It also has a billet servo by PATC (I believe that's what it said) The 1-2 shift sucks. It's like it will hold first gear just a tad too long then when it does shift it's not the usual crisp shift that it should be when just cruising along It's kinda like a bump and push all at the same time. I know that doesn't really make sense but its hard to describe. I had to install a new TV cable because the old one was some Mickey Mouse POS. Got it in and adjusted properly. Still shifts stupid. While the pan was off I pulled the 1-2 accumulator to see if it was blocked. It wasn't. I remember blocking it when installing the original Art Carr shift kits back in the late 90s. (Still have the install manual). I am thinking that the servo cushion spring is not installed. I will check that in the morning. Would there be any downsides to blocking the 1-2 accumulator even though the rest of the "shift kit" isn't an Art Carr or whatever other brand that blocks it? There is not slippage and 2-3 shift is good. Thanks.
