Transgo Shift kit ?'s
Blue87T
I currently have my trans apart due to the clutch material on the converter coming off ( not sure how that happened ). Everything looks ok but I would like to make some changes while its out . The trans was built back in 99 by someone I was told at the time was good with GN transmissions. Mine didnt have the correct valve body and after a few tries at using the one in the car I was finally able to convince him to put the correct one in ( I bought and delivered it to him ) .
Now that I have the trans apart I am not happy with what I am finding . It was supposed to have a 10 vane pump and doesnt, and the one accumulator piston is now 2 nuts and a washer.
Is the lack of accumulator piston hurting anything?
I will be removing the Superior super servo due to harsh 3-2 downshift .
The valve body kit is Transgo 2004r-2-3 . I want to remove that but am reading about the drilling that may have been done . Is it just the spacer plate that would have been drilled or the valve body itself ? What measurements would I need to check to see ?
someone called me with the same complaint today and i advised them to replace the seperator plate.they do mods to the governor circuit that cause second gear starts with higher than normal line pressure or tv setting.
That person was me :)
I appreciate the the time you spent explaining stuff to me and hoep to get the parts I ordered into my car this weekend to try it out.
Thanks again
