ITSAV6
It's my Granny's car!
- Nov 13, 2001
My TPS shows 4.99 on my GEN II sensor page even with the tps unplugged. I just installed it with the plug n play harness. It would fire off and run about 2 sec with the extreme G chip installed. I set it to stock maf output and put my Reds 93 and it will run but idles high. I found the tps voltage then. Any ideas? Im gonna go now and check it with my meter and see if tps volts matches.
