gunzandgearz
gearzandgunz
- Aug 24, 2015
Agree with that,not sure what coolers you use personally or what you recommend to your customers but you ought to try the setrab brand,it's what I use on my stuff and my customers cars,pretty much what all the NASCAR boys use and no one is making more heat in their transmissions and rear diffs than those guysMost important part here is how the oil goes thru the external cooler which should be a LPD design. If it is mounted vertical, it has to fill from the bottom up. If mounted horizontal, I mount in such a way as to have a low side. Keep the lines as short as possible. Testing I did back in the early 90's allowed me to create problems in the 200-4R by using different cooling configurations. This info is more related to use of a Lock-up but should be followed for non-lock as well. I will not warranty a trans unless cooler configuration is correct. Photo evidence is sometimes provided. Protect your investment for years to come and get the cooler configuration correct.
