transmission crossmember?
luisturbog
UNDERDOG HOT AIR !!!!!!!
I need a transmission crossmember, anybody have one? G body (overdrive trans"2004r")
I wish I was going to bowling green! Thanks for that offer though! I hope I find that many people with one out here in the sfv.
Keep in mind that turbo cars have the rubber isolators for the trans crossmember. A Monte ss or a non FI Gbody does not use them. They will be different.
I have a good set of X-member to frame bushings if you need those too, once you find a x-member. I live in NorCal, so they're in good shape. Sorry, I don't have any leads on a x-member. Good luck with your hunt.
John A, Turboohh
I'm finally crossing this bridge. I installed Tranmission last night & the crossmember I had is for th350. I really need to find one soon. Hopefully local.
