Turbosix6
PORSCHE KILLER
- May 31, 2001
Okay, totally fresh rebuild with all of Bruces parts + servo
After a run or extended driving - it will try to launch in 2nd gear from a stand still. If I put it into 1st manually it launches just fine.
I tried putting it in low first & then into overdrive and it launches better , but I still think it launches best in low.
Am I losing pressure somewhere or is there a stuck valve.
The T.V cable adjustment seems perfect with shift timing on the money.
