- Aug 10, 2009
Anyone had this problem before? At idle my TPS reading is 0.44v, but at WOT I can get it no higher than 4.40v. I've tried a new TPS with the same result. It seems the max range is 3.96v even when I position the TPS as far forward as possible. If I adjust it up to reach 4.5v at WOT then the idle value is too high at 0.64v. Is there a way to adjust the linkage to get more range? Are the 70mm TB and 70mm plenum causing a geometry problem that won't allow the range?
Any ideas?
