3.8L V-8 eater
- Jul 22, 2006
Hi, to all
I raced at the Buick event yesterday in Norwalk, Ohio...Lots of fast cars and had a good time!!
Here's the deal. My combo is the same with the only change being going from a 6262 CEA to a 6265 CEA...My first pass was 11.1 and 60ft was 1.7, but only at 120MPH car when right is usually at 123 to 125..Did not record the pass on power logger...Second pass was 11.0 and 60ft 1.4 but only 118MPH so I knew something wasn't right, but I did record that pass
Looking at the data I noticed my boost quickly ramped up to 25 then back down then back up bouncing around till about 90mph then just a slow steady decline with me going through the traps at only 18lbs??? Car did not miss or sputter running fine no codes scanmaster numbers look fine no knock etc....After I got home I took the car back out recorded a few more logs and the only thing I see that doesn't jive is the maf numbers seem low to me...I have it on right setting in PL for the Extreme chip, but maf numbers at 25lbs of boost was 490G/S......Should that not be higher??? Also TPS was only 4.1 did not remove floor mat, but that should not cause low boost issues either...
