As stated above, I removed the 4 bolts in the rear that attach the DS to the differential, with car in neutral, it wont budge. Any tips, or am I missing something? Hammertime?
Is car jacked up/supported by frame so rear end is hanging? If supported by rear end, the DS my be nearly at it's travel limit forward into the trans and won't go any farther forward. Let rear end hang, and then hammertime... easy though!!
With the car's rear axle hanging, you should be able to slip the driveshaft forward inside the transmission just enough to clear the rear yoke enabling you to pull the driveshaft out...If it's stuck in the rear yoke, use a little pry bar between the yoke and u-joint to loosen it...
Good luck!
