I'm considering selling my TRZ front suspension parts. All parts have 6 passes and about 30 miles on them.
The uppers are the pro version with rod ends. The lowers are setup for coilovers and f/a-body ball joints. This means you have to run a-body spindles and brakes. The a-body spindle drop a lot of weight vs. a stock spindle.
The coilovers I have are 3" travel afco's with 10"- 400lb. hypercoil springs and TRZ coilover kit. One shock has some rubbing wear from when I had qa1 coil springs on it but still works fine.
The spindles are a stock set of a-body disc brakes spindles with a set of 11" vented wilwood 4 piston brakes. I have a set of custom steering arms to go with these and a bump steer kit.
A-arms $750
Afco shocks and coilover kit $700
Spindles, Brakes, Steering Arms and bumpsteer kit. $950
Buy all of it together and I'll sell it for $2250
A-arms $750
