Tsm Car 87 Limited
turbot990
A member since 05
Im thinking of selling my race car wich you can street drive this car my car has turned the best of 9.64 at a 139,mph with a 1.356 60.FT. the new motor is a 250 cubes with 3.625 LA. BILLET CRANK STAGE 2 6,200 CON.RODS TITANIUM GN1 14 BOLT R HEADS WITH HEAD CLAMPS SOLID BILLET ROLLER 83 PND INJ. CHAMPION ALUM. FUEL RAILS CAMSHAFT RJC GIRDLE AND OIL PAN HI VOLUME TIMING COVER ALL ALUM. PULLEYS 3 INCH DOWNPIPE ADJ BOOST VALVE IN SIDE THE CAR 70 GTQ V/1 FRT MOUNT GRIFFIN ALUM. RADIATOR DIS 4 WITH 2 STEP LONNIES SPRAG LESS 400 TURBO WITH TRANS BRAKE BRAD 3500 STALL 9 INCH CONVERTOR 8.5 10 BOLT WITH STRANGE SPOOL MOSIER AXELS 90 THICK WALL DRIVE SHAFT Q A 1 10 WAY ADJUSTABLE REAR SHOCKS ANTI ROLL 90/10S SHOCKS ON THE FRT 3 IN STAINLESS SINGLE SHOT EXHAUST NOTCHED FRAM 2 AREO MOTIVE FUEL PUMP TO SUPPORT UP 1400 HP 8 GALLON CELL 8 POINT REMOVABLE ROLL CAGE GNX STYLE COMPLETE DASH PACKAGE WITH ALL PHANTOM GAGES XFI DATA THE DATA RECORDED AND THUMP WHEEL MINI STARTER STAGE 2 POLY MOTOR MOUNTS ADJUSTABLE UPPER REAR CONTROL ARMS FROM HR PARTS FIBER GLASS BMPERS THERE IS NO RUST AT ALL ANY WHERE THE CAR HAS ORIG 70,000 MILES T TYPE LIMITED AND HAS A ALUM CORE SUPPORT ITS READY FOR THE TSM RACE AT BG. i no im for getting some things if you any questions PM.ME or just ask on the board :)$ 25,000 turn key
more pics
Im thinking of selling my race car wich you can street drive this car my car has turned the best of 9.64 at a 139,mph with a 1.356 60.FT. the new motor is a 250 cubes with 3.625 LA. BILLET CRANK STAGE 2 6,200 CON.RODS TITANIUM GN1 14 BOLT R HEADS WITH HEAD CLAMPS SOLID BILLET ROLLER 83 PND INJ. CHAMPION ALUM. FUEL RAILS RJC GIRDLE AND OIL PAN HI VOLUME TIMING COVER ALL ALUM. PULLEYS 3 INCH DOWNPIPE ADJ BOOST VALVE IN SIDE THE CAR 70 GTQ V/1 FRT MOUNT GRIFFIN ALUM. RADIATOR DIS 4 WITH 2 STEP LONNIES SPRAG LESS 400 TURBO WITH TRANS BRAKE BRAD 3500 STALL 9 INCH CONVERTOR 8.5 10 BOLT WITH STRANGE SPOOL MOSIER AXELS 90 THICK WALL DRIVE SHAFT Q A 1 10 WAY ADJUSTABLE REAR SHOCKS ANTI ROLL 90/10S SHOCKS ON THE FRT 3 IN STAINLESS SINGLE SHOT EXHAUST NOTCHED FRAM 2 AREO MOTIVE FUEL PUMP TO SUPPORT UP 1400 HP 8 GALLON CELL 8 POINT REMOVABLE ROLL CAGE GNX STYLE COMPLETE DASH PACKAGE WITH ALL PHANTOM GAGES XFI DATA THE DATA RECORDED AND THUMP WHEEL MINI STARTER STAGE 2 POLY MOTOR MOUNTS ADJUSTABLE UPPER REAR CONTROL ARMS FROM HR PARTS FIBER GLASS BMPERS THERE IS NO RUST AT ALL ANY WHERE THE CAR HAS ORIG 70,000 MILES T TYPE LIMITED AND HAS A ALUM CORE SUPPORT ITS READY FOR THE TSM RACE AT BG. i no im for getting some things if you any questions PM.ME or just ask on the board :)$ 25,000 turn key
or best offer
Beautiful. Yeah, go for eBay or Craigslist.
Craigslist works better in my opinion since it's local, most of the time.
That, and the fact that it's free.
