Im thinking of selling my race car wich you can street drive this car my car has turned the best of 9.64 at a 139,mph with a 1.356 60.FT. the new motor is a 250 cubes with 3.625 LA. BILLET CRANK STAGE 2 6,200 CON.RODS TITANIUM GN1 14 BOLT R HEADS WITH HEAD CLAMPS SOLID BILLET ROLLER 83 PND INJ. CHAMPION ALUM. FUEL RAILS CAMSHAFT RJC GIRDLE AND OIL PAN HI VOLUME TIMING COVER ALL ALUM. PULLEYS 3 INCH DOWNPIPE ADJ BOOST VALVE IN SIDE THE CAR 70 GTQ V/1 FRT MOUNT GRIFFIN ALUM. RADIATOR DIS 4 WITH 2 STEP LONNIES SPRAG LESS 400 TURBO WITH TRANS BRAKE BRAD 3500 STALL 9 INCH CONVERTOR 8.5 10 BOLT WITH STRANGE SPOOL MOSIER AXELS 90 THICK WALL DRIVE SHAFT Q A 1 10 WAY ADJUSTABLE REAR SHOCKS ANTI ROLL 90/10S SHOCKS ON THE FRT 3 IN STAINLESS SINGLE SHOT EXHAUST NOTCHED FRAM 2 AREO MOTIVE FUEL PUMP TO SUPPORT UP 1400 HP 8 GALLON CELL 8 POINT REMOVABLE ROLL CAGE GNX STYLE COMPLETE DASH PACKAGE WITH ALL PHANTOM GAGES XFI DATA THE DATA RECORDED AND THUMP WHEEL MINI STARTER STAGE 2 POLY MOTOR MOUNTS ADJUSTABLE UPPER REAR CONTROL ARMS FROM HR PARTS FIBER GLASS BMPERS THERE IS NO RUST AT ALL ANY WHERE THE CAR HAS ORIG 70,000 MILES T TYPE LIMITED AND HAS A ALUM CORE SUPPORT ITS READY FOR THE TSM RACE AT BG. i no im for getting some things if you any questions PM.ME or just ask on the board
$ 25,000 turn key
