SignUp Now!a
b
a
c
everybody runs the t-4 flange
i,m really getting tired of all the bull sh---t
i may just forget about it.
run outlaw at my local tracks and have a good time!
1) Class weight:
a)3200 b)3300 c) 3400
2) Weight penalty for liquid intercooler:
a) no penalty b) 50# c) 100#
3) Weight break for 275DR
a) no weight break b) 50# c)100#
4) Allow any 88 turbo
a) No b) Yes c) Yes with a weight penalty
Chris, the current 3200# was only if certain deductions were made. Just so I'm clear, you are saying A C C A? I was waiting for your input before we move forward.
Based on this voting. Here's what I propose:
BASE WEIGHT OF 3250#
50# PENALTY FOR A LIQUID INTERCOOLER
NO WEIGHT BREAK FOR A 275 RADIAL
IF YOU RUN A TURBO LARGER THAN 47/88 YOU MUST RUN A 275 TIRE
Other than change some of the addition and deduction penalties I see no reason to change the core set of rules at all. Are you planning to use the core rules the point series has run since 2007?
http://www.turbobuick.com/forums/ts...7263-2010-tso-top-gun-point-series-rules.html
If not I have several questions that will affect how my car is being built right now. Such as: Can I run spindle mount wheels? Will I be able to relocate the upper frame mounts? WIll I be able to run a fiberglass dashboard and will I even need one? Will I be able to run a pin on front end? Will I need headlights and a grille? Can I run alcohol and will I need a radiator? Can I run lexan windows and do they need to be operable? Can I run a lenco transmission? Do I need an exhaust or can I dump it out the fender in front?
If I am reading right, the any 88 turbo won right?
<<SNIP>>
My reason for the last rule is simple: The only reason we are changing the current turbo rule is to get closer alligned to the X-275 class. So if a guy is going to a larger turbo to run X-275 he needs to run 275's
I think Donnie Wang can even play with his 91mm if he wants to run on 275's![]()
If everyone is OK with it this way or they just want to try it out and see I'm OK with it. I go back to the X275 rules, do they penalize for a larger than 47/88 turbo?
I think the last rule is actually going to give an advantage to a 275-tire car just when they need it. The larger turbos are going to be harder to spool than the 47/88 and softer down low. I think the larger turbos are going to really start pouring on the coals down track when the 275 is working to your advantage. I think you'll see a car with 275's and a larger turbo really put up some big numbers compared to a slick+47/88. I think this rule is again assuming a slick has an advantage over a radial and penalizing it.
