turbotaguy
- Aug 7, 2006
Newbie here - I've got my TTA running pretty well now and just wanted to check on my WOT air/fuel. My scanmaster reads around 830-835 at WOT, is that OK?
Is there a conversion from Scanmaster 02 voltage to an A/F ratio?
My WOT run was at 15.5psi with 835 o2 voltage and 0 knock retard. Just looking to make sure the a/f ratio is good before I crank up the boost to 16.5psi where it should be (via adjustable wga).
