72firebird
- May 18, 2004
Well decided to take the car out again to try to beat my old stock (just open downpipe) time of a 13.4 and I did it.
Details of the run:
60' - 1.892
594' - 7.846
1/8 - 8.392
MPH - 82.40
1/4 - 13.155
MPH - 100.94 (best of a 101.8 that day on a 13.2)
72Firebird TTA car #1105
EMPTY WEIGHT: stock
BLOCK: stock
HEADS: stock
CAM: stock
TRANSMISSION: stock
TORQUE CONVERTER: stock
DIFFERENTIAL: stock
INTERCOOLER: stock
THROTTLE BODY: stock
RJC POWER PLATE: stock
INJECTORS: stock
THERMOSTAT: stock
TURBOCHARGER: stock
VALVE SPRINGS: stock
MAF: stock
DOWN PIPE: stock
EXHAUST: Open cutout
FUEL PUMP: stock
FUEL PRESSURE REGULATOR: stock
FUEL PRESSURE: stock
ALCHOHOL INJECTION: none
PROPAIN INJECTION: none
NITROUS: none
AIR FILTER AND AIR INTAKE: 3" hard Up Pipe and MAF pipe with 7" filter
TIRE DESIGN, SIZE & AIR PRESSURE: Nitto 555r 245/50/16
AIR BAG(s): none
SUSPENSION: stock
SCAN TOOL: forgot it at home but Turbolink
FUEL: 93 Octane
CHIP: stock
CHIP TIMING: stock
KNOCK RETARD: ?
OXYGEN SENSOR VOLTAGE: ?
EXHAUST GAS TEMPERATURE: ?
TRACK ELEVATION: 757'
TEMPERATURE: 75
PEAK BOOST: stock 16.5
BOOST AT LAUNCH: ~5 psi
MILES ON THE CAR/ENGINE: 20k
Overall I'm very pleased with the run considering the very few mods done to it.
Details of the run:
60' - 1.892
594' - 7.846
1/8 - 8.392
MPH - 82.40
1/4 - 13.155
EMPTY WEIGHT: stock
BLOCK: stock
HEADS: stock
CAM: stock
TRANSMISSION: stock
DIFFERENTIAL: stock
INTERCOOLER: stock
INJECTORS: stock
THERMOSTAT: stock
TURBOCHARGER: stock
MAF: stock
DOWN PIPE: stock
FUEL PUMP: stock
NITROUS: none
AIR BAG(s): none
SUSPENSION: stock
FUEL: 93 Octane
CHIP: stock
CHIP TIMING: stock
KNOCK RETARD: ?
TEMPERATURE: 75
