SignUp Now!2QUICK2B6 said:what #'s do you think a stock block 20 over girdled with ported stock heads
PT61 with an S cover 4'' inlet, 3200 PTS converter ,50lb inj , cam , 70mm TB , accufab plenum RJC plate is good for in the 1/4 ?
Grumpy said:maybe high 10's down to 13s....depends on the tune![]()
BlackRob91 said:How does a transbrake work and isnt it reall hard on your car?![/QUOT
it finds the weak link if there is one![]()
Grumpy said:BlackRob91 said:How does a transbrake work and isnt it reall hard on your car?![/QUOT
Dan, how well do you think the stock driveshaft and stock 9 bolt would hold up with a trans brake? I kind of considered getting one but I don't think I could afford to replace all the parts I'd probably end up braking with it.
Razor said:You dont mean the scales at Beech Bend that everyone two weeks ago was complaining about reading too little.![]()
