tta parts needed
cruesix
topless tta
i need a driveshaft for a tta i also need part of the trans crossmember i have the big part that looks like a boomarang i need the part that attaches to the trans and the torque arm,i also nee a down pipe..PLEASE HELP:D i cant finish until i find these parts...really want to drive it soon..thanks
dan
cruesix@comcast.net
Are you looking for a stock downpipe? i know of a few that could be up for sale-
also, to help you out, you need to search lips in or lips out for the torque arm bushing that attaches to the trans....
You may or may not have this part and not know about it.
BW
stock downpipe would be fine..as far as the crossmember im not sure i understand what you said:confused: the crossmember if i remember correctly is two seperate pieces the "boomarang"that bolts to the subframe and then another piece that attaches to the trans mount and the crossmember and im assuming the torque arm mount attaches to it somehow..im not sure though its been several years since i saw one..i have tons of parts for the regular 350/700r4 set up but they attach to the tailshaft on the trans.and this appears to be completely different..any help is more than appreciated..thanks
right, i will have some pics for you on monday evening if possible-
the torque arm has a bushing that attaches it to the trans, either lips in or lips out, i forget... but i will get you some stock pics from a buddy of mine in nashville.
HTH
BW
