It's a catch 22 Matt. With the camber between .1 and -.1 degrees (same on both sides) you get the least edge wear on the tires. Once you add the higher caster angles then the ackerman and camber curves take effect. Optimum to reduce overall tire wear would be 3 degrees total on passenger side and .4 to .5 lower reading on the drivers side. Not the best for handling but it reduces the edge wear.
I'd at least replace the end links once all the mods have been done and you can make sure that the front bar is level to the ground. I'll bet the ones you have now will have the bar tilted up some.
