Tuning Alcohol/Water Injection
  • Thread starter Thread starter Blown93LX
  • Start date Start date
I'm going to order a couple kits from the 'Aussies', we shall see how it goes... :)
Originally posted by FastGSXauto
How are you guys mounting the mcmaster nozzles into the pipe (or manifold)? And how are you connecting the water line to the nozzle? I have a very ghetto setup right now and I'm trying to see if there is a cleaner way to mount and feed them. Thanks!
I don't think I'll be of much use to you. You'll need help from a GN guy. I just don't want you to think I was ignoring you. :)
I have an aluminum discharge tube that's easily taken off. I simply drilled a hole barely big enough for the nozzle which has a tappered seat. I used a sealing washer on the outside.
Ed
Guys
I will be spraying on a KB before the TB. Should I get a nozzle that sprays at a 90* angle, or will spraying straight into the pipe be ok?
Gary
spraying straight in should be fine. The air will be moving at a very high velocity and it will not make any difference. We normally spray straight in.
