ek02
- Jan 31, 2008
Maybe some of you guys with Nitrous experience can give me some input. I installed a wideband air/fuel guage on my N/A 274" setup. I have a NOS Super Power shot plate system with a dedicated fuel sytem for the nitrous solenoid with a return line to the tank regulated at a steady 6 PSI. After I rejetted my carb, my A/F ratio at wide open throttle is 12.5-1 and 14.7-1 cruising. When I hit it with a 125 shot of N2O, the A/F goes to 10-1, the lower limit of the gauge. I leaned out the fuel jet .004 and got 10.2-1 for a second, and then back to 10-1. I put the recommended fuel jet back in (.061) and upped the N2O jet .002 to a .057. Same reading. I was looking for 11.5-1 but can't seem to get there. I hate to go too far from the 125 shot jet recommendations. My bottle pressure was 950 PSI and total timing is pulled back to 26 degrees by the MSD box when I hit the spray. I called NOS tech support and the guy said he never heard of tuning a nitrous sytem with a wideband. I can always read the plugs as suggested, but it's a little hard to cut it clean at night and pull the plugs at the end of the track. I can also switch jets between runs and see what the mph does, but using the wide band should be the safest and easiest way to jet this thing. Is 10-1 too rich, and would I see any HP gain at 11.5-1?
