i have everything all together and i dont have any reference as to what  an acceptable amount of endplay is. what do you guys recommend? i should be able to just shim the  bottom of the pump, right? add another thrust washer?
right now with the pump bolted in, while pulling up on the forward drum shaft i have .65 of endplay. it seems like waay too much. any input on this is greatly appreciated. i want to make sure everything is a-1 on this thing since its going to see alot of abuse.
