many yrs ago, w/ my first 400. I did the mod, and we tested it out. Found that turbobitt's value of 75 was there. We then changed the drill from 7/64, to 3/32.. PSI dropped to 40's...
We think it may vary, trans to trans, as mentioned by turbo bitt/Bison. Yes? No?....
THANKS Don!![]()
To answer your question, most certainly! One pump specification that contributes to over-feeding and over-pressurization of the torque converter, other than the normal feed passage in the pump cover, is the pump gearset face clearance. Even with the proper restriction placed in the T/C feed passage, if excessive clearance is present at the gearset face, oil pressure will crossleak across that clearance, directly into the feed oil circuit to the T/C. That would explain why some have used the recommended 7/64" orifice in the T/C feed passage restrictor, but still had too high a cooler line pressure. The excessive pump gearset face clearance could easily be labeled a crossleak from the high pressure cavity of the pump pocket directly into the torque converter feed circuit. The potential of this crossleak is directly related to the amount of line pressure that the unit is setup with.
To control this potential crossleak problem, keep pump gearset face clearance to no more than .001". No less than .001". Yes, the specification should be right at .001".
A good example of how important face clearance really is. Back when Chrysler TorqueFlite, lockup T/C, 904 transmissions were around, it was very common to see them kill the engine when the shifter was put into reverse. In reverse, in any transmission, the pump generates higher line pressure than in the forward ranges. The higher pressure in the pump cavity would crossleak directly into the T/C feed circuit, causing excessive fluid flow volume and the lockup clutch in the T/C would apply and kill the engine. If those pumps were not kept to no more than .002" pump gearset face clearance, preferrably .001", this would happen. .003", which is a perfectly exceptable max limit for most transmissions, would most definitely cause the T/C clutch to engage and kill the engine.
I cannot over state the importance of maintaining a proper pump gearset face clearance. The normal flow pattern to feed the T/C goes from the pressure cavity of the pump gearset pocket to the pressure regulator valve, and from there it is regulated by the PR valve and continues on to feed the T/C. A crossleak from the pressure cavity of the pump gearset pocket to the T/C feed circuit is direct. The pressure is not regulated at all except by the face clearance of the pump gearset, bypassing the PR valve all together.
Lots to think about in a transmission. Not the simple beast some think it is.
