turbo adjustment
dank GN
BlackArts Automotive (661)993-8277
how do i adjust my turbo? the turbo outlet it pointing a little to high? can i adjust it?
Yes, There are some 10mm (i think) bolts on the back of the compressor. Loosen those just a tick and you can "clock" the compressor anywhere you want.
on the back of the turbo cold side they're 13mm or 1/2 depending on turbo as some use std hardware some use metric even though 1/2 and 13mm are usually interchangeable
, the four 10mm(sometimes 3/8) by the center section is for the cold side backer plate.. dont loosen those ..
loosen the ones near the outside edge and the housing should rotate . be aware if you're on an internal wastegate setup that you'll be moving the wastegate actuator which could affect the boost so becareful when spooling that you dont over boost
