x96283
- Mar 18, 2013
Alright! First time I can make a substantial post!
First off, I'm new to the Turbo Buick world. Bought my car off this board back in March and transported it to Hawaii. There is a shortage of TRs to choose from on Oahu, so I knew I should "import" one. I'm trying to learn as much as I can and have been diving into the forum here almost nightly.
Car currently has 60k miles but don't let that fool ya-- appears to have been raced in a prior life. My overall goal is to establish reliability and safety baseline before performance improvements. I can only get 92 octane and looking down the road at an alky kit... well, the local methanol supplier is $84 per 5 gal can. Not exactly cheap. Denatured alcohol at HD/ Lowe's is $17 per gal too. Shoot, gas is 4.47/gal too!
So, here's a quick snapshot of the car as it is now. I'm ok replacing items with better quality parts (OE or aftermarket) either as preventive maint or during repairs. I can always add something to the shopping list if you see something that should be changed out. Cotton's gave the car a once over and the factory parts are still within spec (new fluids/ filters too). Trans upgrade is probably the largest item looming on the horizon.
Parts recap:
Stockish Engine refresh, 30 over build
204/214 flat tappet
Double roller timing chain
100lb Valvesprings
Basically stock trans, a little more stall I've been told
Garrett old school Stage 2 (58mm wheel) .82 housing
Ported Exhaust Elbow (GBodyParts)
Pypes exhaust with test pipe
Stock MAF/ 3-in Cotton's intake pipe/ K&N
Walboro 340
60lb inj
TT chip (from Cotton's... street #1 8523, v5.7 60#, 20`/18` 16-8psi)
Stock mod adjustable FPR to 43lb vac off as best I can see on the little rail gauge
Scanmaster
So far I've think it's been running ok... but then again, I'm new to turbo Buicks so what do I know?
Some data that I captured (love my phone's dictation app):
12 JUNE, at 2am (figured it would be as cool at it gets around here)
Cruise at 56mph
O2 675, 199, 794, 316, 203
AF 17-20
L8 53, 58, 60
BAT 13.3
INT 127, 135, 126, 134, 120, 133, 132, 125
BL 136
MPH 56
CLT 189
ATS 82
r 1775
TPS .94
IAC 47, 57, 53, 45, 48
cc 150, 186, 214, 240, 08, 31, 65, 81, 115, 132, 146, 161, 184, 209, 227, 242, 09
MAL none
Finished cruising and at hot idle
O2 824 839 835 820 816 835
AF 6
L8 41
BAT 13.4
INT 128
BL 133
MPH 0
CLT 187
ATS 112
r 825ish
TPS .44
IAC 5, 4
cc 91
MAL none
29 MAY, 3pm
cruise 55mph
O2 703
AF 18, 17
L8 41
BAT 13.2
INT 127
BL 134
MPH 55
CLT 184
ATS 93
r 1700
TPS .66 .64
IAC 57
cc 54 156 169 191
MAL none
Hot idle
O2 800
AF 07
L8 44
BAT 13.3
INT 128
BL 129
mph 0
CLT 193
ATS 126
r 825
TPS .40
IAC 25
cc 133
MAL none
I forgot to capture any WOT blasts, but generally speaking they are around 820 and no real KR. I think I need to apply throttle more smoothly. I think I'm seeing false KR (e.g., 0.7, 1.2) on shifts, shakes and bangs. A brief WOT blast on the highway shows no KR. Is it better to mat the pedal and run it from 1st to 3rd, or a smoothly applied rollon in 3rd? How long?
So looking ahead at my to do list...
To install (parts already on hand):
2 5/8 Autometer FP gauge via hood mount
Audible knock detector
Casper's FP hotwire
ACDelco Fuel filter
To buy:
Boost gauge. Been impossible to find a shop with inventory on island so I'll be ordering soon. Got my eye on a Sport Comp vac/ boost combo.
I feel that I'm still too "green" to interpret the data correctly and I don't want to chase numbers. However, BL seems on the high side, yet the O2 seems rich. I've been searching the forum a lot and making a punch list to check for vacuum leaks, but a quick check with carb spray didn't show anything. I hope to get it on a lift this week to poke around and I've also been looking for a shop with a smoke machine. Also, on my next fill up I will calculate some mpg data too.
Any comments? More specific data required?
Thanks much!
--matt
Parts recap:
204/214 flat tappet
100lb Valvesprings
Walboro 340
60lb inj
Scanmaster
Cruise at 56mph
AF 17-20
L8 53, 58, 60
BAT 13.3
BL 136
MPH 56
CLT 189
ATS 82
r 1775
TPS .94
MAL none
AF 6
L8 41
BAT 13.4
INT 128
BL 133
MPH 0
CLT 187
ATS 112
r 825ish
TPS .44
IAC 5, 4
cc 91
MAL none
29 MAY, 3pm
cruise 55mph
O2 703
AF 18, 17
L8 41
BAT 13.2
INT 127
BL 134
MPH 55
CLT 184
ATS 93
r 1700
TPS .66 .64
IAC 57
cc 54 156 169 191
MAL none
Hot idle
O2 800
AF 07
L8 44
BAT 13.3
INT 128
BL 129
mph 0
CLT 193
ATS 126
r 825
TPS .40
IAC 25
cc 133
MAL none
Casper's FP hotwire
ACDelco Fuel filter
To buy:
Thanks much!
--matt
