Starman said:you will immediately go into the 10's with 21-22 pounds of boost....you time is great right now for 17 pounds..
Not on 93 octane.
what do you have as far as equipment?
Not on 93 octane.
Now that I have the Alky, why would anyone want to run around with pump gas only and being restricted to 17 lbs of boost? That is like racing at half throttle, or going to a whore house without your pecker. LOLMy car now stays on 24 lbs of boost, it is ready to do battle 24-7. Also, the extra timing gives it a crisper throttle response.
I agree alky and race fuel are equals and obviously have huge power gains....but to my point neither are just "pump gas"
Dennis Hogan has run a 10.16 @ 136+ on Pump gas and dual nozzle methanol. StageII 274", TA Eliminator heads, TA headers, 215/220 Hyd Roller cam, TA oil pump, 200-4R built by Dave Splett (425) 774-4966, 80 lb injectors, STOCK ECM with Eric Marshall chip, Stock location intercooler, Three Muffler system in 2.5", Drag radials, HR Parts rear sway bar, 'glass hood and bumpers, full interior, and a real street car. With a 3.8 liter 109 block, Champion heads, it just ran a 10.34 @128 (while I was freshening up his stageII). This is the same car that made it into the top 32 on PINKS in Seattle. We had THRASHED to get an engine built to make it to the race. Barely made it and he tuned it to a 10.50 figuring that would be the break point. Wrong guess, though. The break point was 10.32 give or take. It is a great little street car. It'll scare the life outta you if you've never riddin in a low ten second street car. It is church mouse quiet and runs like Godzilla! Ride is smooth and quiet. Definately going fast with class.
Steve, tell me more about the "extra timing"....how much timing do you run?
Wow that's "getting it done" times right there!!! !! Where did your signature go?? Wanted to see your build running those #'sLast Friday night on 93/alky, my 87 GN ran a 10.99 @ 124.79 on a test pass on 19-20 lbs of boost with a no boost launch. 60 ft was 1.881.
Ended up the night with a 10.447 @ 128.92 on 21-22 lbs of boost. 60 fo0t was 1.499.
Depending on the weather, going to the track this Friday to see what it will do with 25 lbs of boost. Last spring before the new tune, it went from
10.428 @ 129.79 on 24 lbs of boost with a 1.491 60' to 10.373 @ 131.88 on a 1.582 60' while breaking 3 teeth off the ring gear and still ran best ever MPH on back half of the track at 27.11.
Alky is the way to go for a street car, cruise around on pump 93 and if you get on it for whatever reason it's there. Me, I rarely get past 5 psi boost on the street, so I never use much alky. But I can drive to the track and not touch tires or tune or anything and have fun there and drive back knowing its faster than a stock C6 Z06 even from a roll and if I lock the converter it picks up 30+ mph from 1/8 to 1/4 mile. I don't have much time to mess with the car anymore so I am keeping it simple.
lookin at your sig you have the capability of high 9s. You have more stuff than we had except for our 67 turbo.
That's where I am trying to go. Hope to run find out tomorrow night.
I don't have your talent and experience in tuning and a lighter and better driver like Melissa would also help.
